Hello everyone. Welcome to the Live Demo Screen for Templot. If you can see anything below when you click start > on the image, it is a live broadcast stream from my computer. If it is showing Templot running, you can post live help requests and support questions by opening the Chat Box below the stream. I will do my best to respond to questions and demonstrate the answers. You must be a member of the Templot Club forum to use the chat feature - you can Login on the Chat Box, or Register as a new member by clicking here. Please ask on Templot Club for more about this feature, and times when it will be live. See also the video archive of previous live demo sessions. Martin. |
The Templot Club forum will open here at the Chat page. Scroll back up to continue watching the stream.
If you have a widescreen monitor you may prefer to have the Chat Box alongside the stream image instead. To do that, hold down the SHIFT key and click separate Chat Box. It will open in a separate browser window. You can then resize your browser windows to have both windows showing side-by-side.
If you would prefer also to watch the stream in a separate browser window, hold down the SHIFT key and click here. The stream image will zoom to fit the width of its browser window. The stream can also be watched on the Twitch web site at: https://twitch.tv/martintemplot. Please note that I have no control over the working or content of the Twitch web site.
To hear the audio commentary, you may need to unmute the loudspeaker icon on the stream, or in the browser tab at the top of your screen.
You can watch the stream full-screen by clicking the [ ] icon at the bottom-right corner of the stream -- but you won't be able to use the Chat Box at the same time. In some browsers a better option is to press the F11 key to toggle off the browser header rows only.
If necessary to get the stream started, press CTRL+F5 in your browser, or click or tap whatever is needed on your device to Refresh the page. You may need to do this more than once to keep it running if it seems to have frozen or the buffering roundel is rotating for a long time.
Thanks for watching.
link to this page: https://c7514493.myzen.co.uk/dokuwiki/doku.php?id=live_screen
