This function is primarily for use after using the make transition function.
For an example of these functions in use, see how to... .
The control template is extended or shortened as necessary to make a neat boundary with the selected background template, at the selected peg position:
With the result:
Note that for this function the control template alignment is not disturbed, and the position of the fixing peg within it is immaterial. The template is extended, not shifted.
If a perfectly neat boundary cannot be achieved, a message will appear showing the extent of any small discrepancies, in order that you can decide whether to accept them.
This function is primarily for use after using the make transition function. For an example of these functions in use, see how to... .
link to this page: https://c7514493.myzen.co.uk/dokuwiki/doku.php?id=extend_shorten_to_meet
